1994 Pontiac Bonneville car will not crank when hot
1994 PONTIAC BONNEVILLE
96,000 MILES • 6 CYL • FWD • AUTOMATIC
FIORE MARTONE
when car is hot (so in summer problem more apt to happen) will not start. all lights, horn everything electrical works. but car starter acts as though battery is conpletly dead. the starter has been replaced 2 times for this ( one time mechanic said that voltage was at starter so we replaced starter again which was the 2nd time ) allso new ignition key was made(key has security chip) but no help. when car is hot i must let the car cool down alsmost to point that temp gauge says almost conpletly cold. also if i rev the engine before shuting off seems to make it worse wear car has to sit overnight before it will kick over. so again in winter it doesnt get that overheated and takes less time to cool so problem does not happen so much. also if i shut car off no matter how hot it shows. but turn it on again say in less then 5 to 10 min have passed it will start. so hopefully you can help. let me thank you now for helping
Mar 18, 2008 at 11:15 AM
2CARPRO JACK
  • CERTIFIED EXPERT
  • 11,533 POSTS
Check for 12 volts at the small wire on the starter with key in crank position. If it has power then the starter needs to be replaced. If none, then get back to me and we will figure out where it stops, could be the neutral safety switch,or the starter enable relay (behind left side of dash,left of steering column)
Mar 19, 2008 at 10:33 AM
