Most likely an ignition module, symptoms include, will start when cold and when engine gets hot it will fail and then restart when it cools down.
Most can be tested at autoparts stores for free, I would start there, let us know if module checks out.
If you have a timing light with inductive pickup, start engine and put pickup on one wire at a time, pull trigger on light and look at pulsing pattern, if you notice any difference in flashing pattern when changing to different wires, then coil pak is culprit.
SPONSORED LINKS
Sunday, April 19th, 2009 AT 8:36 AM
