Engine Performance problem
1990 Pontiac Bonneville 6 cyl Front Wheel Drive Automatic 223k miles
The serpentine belt was suddenly detached when I started my ’90 Bonneville. I soon found radiator fluid leaking under the engine. After some investigation, I noticed the water pump hub was bent slightly. The water pump only rotates about 60 degrees with ease and a full turn with force. Rubber marks on the pump hub correspond with the bend on the water pump hub.
What would have caused this problem to occur?
Helpful hints: I live in a cold weather climate. The car has 223k miles. The car still turns over and idols. The water pump was approximately three years old. Occasionally while driving, the battery idiot light has been turning on for short periods of time. Could this have been simply a loose belt problem?
Dec 10, 2008 at 3:14 PM
