The motor stalls on idle. It doesn't seem to matter where I tune the idle mixture screws on the carb base, still stalls. After revving it in the driveway and the motor decreases to idle it wants to stall unless I partially close the choke (increasing vacuum pressure?). It gets worse after the motors warm, even worse when its hot. I can pull out of the driveway OK, but once out on the street, even coasting in neutral, it stalls.
I've done quite a bit so far: I've partially cleaned & rebuilt the 2-barrel vintage Rochester carburetor (set the float twice), rebuilt the ignition (still waiting on the correct contact points assembly) & checked all the vacuum lines. There's no EGR valve (1968 Catalina actually, but very much like the more-optioned '68 Ventura, Bonneville or Executive).
I say "partially" on the carb rebuild: When I rebuilt the carb I just cleaned out the circuits using a straw nozzle from a spray can with some help from a nylon pipe cleaner. I didn't soak the carb however.
I wish I could just adjust the maximum choke intake opening, that'd keep the vacuum pressure up during idle. Should I go ahead & pull the carb again & really soak the base in a bucket of carb cleaner?
What else should I be looking for? I really appreciate any advice you have to offer. This is a beautiful car but this mechanical problem is becoming an obstacle in getting on with the rest of the restoration work.
Thanks in advance,
/lee
SPONSORED LINKS
Tuesday, April 22nd, 2008 AT 12:50 PM
