2001 Pontiac Aztek Key Won't Enter Ignition Fix
CLIFFLAV
My Pontiac Aztek 2001 is not allowing the key into the ignition. It seems to be locked. The key will not even slide in at all. I have disconnected the battery. I have tried the hidden ignition switch under the column. I have tried the gear switch in the cup holder. Any other ideas on why this is happening. When a P3 key is not recognized can you still slideit into the ignition?
Thanks
Cliff
Sep 12, 2007 at 11:50 PM
GMTECH
  • 537 POSTS
make sure the key is not damaged in any way. It seems that the ignition cylinder has dropped a tumbler and is jamming. You need a new cylinder
Oct 24, 2010 at 1:00 PM
Suggested Repair
Inspect the key for damage. A dropped tumbler is likely jamming the ignition cylinder, so replace the ignition cylinder.
Conversation Summary
The owner of a 2001 Pontiac Aztek cannot insert the key into the ignition at all. Disconnecting the battery and trying the hidden column switch and shifter interlock did not help. The expert advised checking the key for damage and said a dropped tumbler is jamming the cylinder, so a new cylinder is needed.
