when i changed the driver side caliper, i made sure the bolts were tight and lubed pretty good. i bled the brake lines and got a good tight brake pedal. but, when i started the car, the brake pedal lost all pressure and went to the floor. i put it into reverse and it moved and only will stop if i press the brakes all the way to the floor. i pumped them and nothing changed.
May 20, 2009 at 11:41 AM
