I just replaced the air pump on this after finding that it was turning up in the OBD codes. It had blown the fuse and when I took the old one off I got about 2 ounes of water out of one of the hoses. The fan had some rust accumulated in it and was frozen. My question is wether the small amount of water I found is normal or wether I should replace the air inject check valve. Its another $90.
Oct 26, 2009 at 3:21 AM
