1988 Pontiac 6000 Exhaust system
1988 PONTIAC 6000
89,000 MILES • 4 CYL • FWD • AUTOMATIC
NORTHERNMICHIGANDER
I am putting on an exhaust system on my daughters car. I am buying the parts from my local NAPA dealer. I want to replace from the Catalytic converter to the muffler. Can you tell me exactly what I need to tell the salesperson at NAPA? The cheapest converter, brackets, and cheapest quietest muffler? Thank you!
Craig
Jan 2, 2008 at 8:18 AM
  • 31,937 POSTS
Hi there ,
thank you for your donation.
Cheap is not always good with exhausts, There are generic catalytic converters, that's not a problem, the interconnection pipes will be a standard shape and size, so you will have to make sure the cat is a comparable size to what you have now. The muffler will also be generic but ask for a better quality, a bit more spent here will pay off in the long term, as for clamps and gaskets off the shelf will be fine, just don't use a sealant up stream of the cat, as silicon based sealants are detrimental to there operation, just use the gasket supplied.
Mark (mhpautos)
Jan 2, 2008 at 9:23 AM
NORTHERNMICHIGANDER
[quote:55fd8d0550="mhpautos"]Hi there ,
Mark (mhpautos)[/quote:55fd8d0550] Thanks but do I buy a "direct fit" or a "universal" fit muffler? It appears that the piping is all fitted to what is on there now.
Thanks!
Jan 2, 2008 at 9:38 AM
  • 31,937 POSTS
As long as the universal fit, is just that, and you wont know until you try it on, go for that, just be careful about the relevant size of the muffler as it may say universal, but it may not have the same clearance as the original and touch somewhere when driving on rough roads. Take a few basic measurements and compare before committing your self.
Mark (mhpautos)
Jan 2, 2008 at 9:55 AM
NORTHERNMICHIGANDER
[quote:846b61d3f6="mhpautos"]As long as the universal fit, is just that, and you wont know until you try it on, go for that, just be careful about the relevant size of the muffler as it may say universal, but it may not have the same clearance as the original and touch somewhere when driving on rough roads. Take a few basic measurements and compare before committing your self.
Mark (mhpautos)[/quote:846b61d3f6]
Any possible way you could tell me just exactly you would order for the muffler to be replaced? Just the muffler and required brackets? I'm not a mechanic but give me the correct parts and I can put it together easily. I would greatly appreciate it. My daughter doesn't need a ticket for such an older car.
Thanks a bunch, Craig
Jan 2, 2008 at 10:19 AM
  • 31,937 POSTS
If the pipes are ok, just order the muffler, have a good look at any rubber mounts, if they look cracked order them as well. if the muffler is flange mounted order gaskets, if slip joints order new clamps, that should get you out of trouble,
Mark (mhpautos)
Jan 3, 2008 at 2:40 AM
