something's wrong with my gauges
PLYMOUTH VOYAGER
IVORY WALKER
I HAVE A 98 PLYMOUTH VOYAGER there are 165,551 miles on it :( AND SOMETIMES WHEN I GO TO START THE CAR MY DIGITAL GAUGES DON't COME ON AND WHEN THAT HAPPENS THE CAR STARTS AND THAN SHUTS BACK OFF NOW IT NOT EVEN MAKING THE STARTING UP NOISE, I HAD A NEW STARTER PUT IN, HAD MY IGNITION BOX REPLACES EVEN PAID 200 DOLLARS TO A MECHANIC AND HE DIDN'T EVEN FIX IT, MY BATTERY IS STILL GOOD, DO YOU KNOW WHAT THE PROBLEM IS
thank you for your help
Oct 11, 2007 at 1:19 PM
BMRFIXIT
  • 19,053 POSTS
[quote:360bbb4404="ivory walker"]I HAVE A 98 PLYMOUTH VOYAGER there are 165,551 miles on it :( AND SOMETIMES WHEN I GO TO START THE CAR MY DIGITAL GAGES DOn't COME ON AND WHEN THAT HAPPENS THE CAR STARTS AND THAN SHUTS BACK OFF NOW IT NOT EVEN MAKING THE STARTING UP NOISE, I HAD A NEW STARTER PUT IN, HAD MY IGNITION BOX REPLACES EVEN PAID 200 DOLLARS TO A MECHANIC AND HE DIDN'T EVEN FIX IT, MY BATTERY IS STILL GOOD, DO YOU KNOW WHAT THE PROBLEM IS
:( :( :( :( :( :( :( :( :( :( :( :( :( :( :( :( :([/quote:360bbb4404]
did any one check the ignition switch
you may need one
if all ok check if all supply B+ on the switck ok
some after market alarms they cut the wiring
good luck
Oct 11, 2007 at 8:55 PM
BMRFIXIT
  • 19,053 POSTS
Ivory walker
October 11, 2007.
165,551 mileage. I had the ignition check, and i disconnected the battery all day, when i reconnected the battery it still wouldn't make it start, I had the wires checked and a diagnostic test it picked up nothing, is there a special test that can tell if its an electric or wire problem
ok lets start over
when you turn the key to on do u have check engine light on?
when you try to start does the engine crank but no start?
Oct 12, 2007 at 7:25 PM
