reverse lights dont work
SERENAS111
i have a1996 plymouth voyager mileage 132000 6 cylinder.i went to get it inspected they said reverse lights don't work.i checked the sockets they work ,i checked bulbs they work,all the other lights on the tail light work except reverse lights on both sides.i thought maybe it was a fuse but i looked and cannot find a place in the fuse box for reverse/back up lights.if it is listed seperately in the fuse box under a different listing please let me know?also could it be something else,i heard about a trans axle range sensory?if it is something like a sensor is it repairable for me to do at home?thank you
serena
Nov 27, 2007 at 10:29 PM
BMRFIXIT
  • 19,053 POSTS
[quote:aa0d798c2e="serenas111"]i have a1996 plymouth voyager mileage 132000 6 cylinder.i went to get it inspected they said reverse lights don't work.i checked the sockets they work ,i checked bulbs they work,all the other lights on the tail light work except reverse lights on both sides.i thought maybe it was a fuse but i looked and cannot find a place in the fuse box for reverse/back up lights.if it is listed seperately in the fuse box under a different listing please let me know?also could it be something else,i heard about a trans axle range sensory?if it is something like a sensor is it repairable for me to do at home?thank you
serena[/quote:aa0d798c2e]
Check the relays under hood relay box and if ok check
Switch and then wiring harness
you can do it
Good luck
Dec 3, 2007 at 12:22 PM
BMRFIXIT
  • 19,053 POSTS
[quote:bee30c8562="serenas111"]i have a1996 plymouth voyager mileage 132000 6 cylinder.i went to get it inspected they said reverse lights don't work.i checked the sockets they work ,i checked bulbs they work,all the other lights on the tail light work except reverse lights on both sides.i thought maybe it was a fuse but i looked and cannot find a place in the fuse box for reverse/back up lights.if it is listed seperately in the fuse box under a different listing please let me know?also could it be something else,i heard about a trans axle range sensory?if it is something like a sensor is it repairable for me to do at home?thank you
serena[/quote:bee30c8562]
you can do it
Good luck
Dec 3, 2007 at 12:24 PM
