2000 Plymouth Voyager Transmission performance
2000 PLYMOUTH VOYAGER
98,000 MILES • 6 CYL • 2WD • AUTOMATIC
BOOGIEMAN277
My daughter has a 2000 Voyager,. She complains that when the vehicle is first started and relativly cold, the transmission works fine. After the engine has warmed up and she has driven a while, the trans mission acts like it dose not want to shift, and the engine idle goes way up.
I am going to change the trans., filter and I was wondering if maybe the park/neutral switch could have any thing to do with it's performance?, or maybe the engine positioning sensor?
How many times should I change the trans. oil if I decide to flush the tranny?
Mar 14, 2009 at 10:35 PM
BMRFIXIT
  • 19,053 POSTS
It requires a special ATF fluid and be very careful of what u use for tranny fluid check if has any tranny codes (check engine light on ?) if any I would suspect speed sensors
https://images.2carpros.com/forum/automotive_pictures/99387_Graphic9_16.jpg
Mar 14, 2009 at 11:53 PM
