2000 Plymouth Voyager clock spring
100,000 MILES • 6 CYL • 2WD • AUTOMATIC
TIGNLEE
I was told that my clock spring or something like that is bad. My horn and cruise control are not working and my airbag light is on. I was also told this would be covered under warrenty if I take it to dealer. Is this right?
Mar 7, 2009 at 10:18 AM
JDL
  • 16,098 POSTS
Hello, call a dealer and talk to the service department.
Mar 9, 2009 at 5:50 AM
CARADIODOC
  • 34,414 POSTS
It's 8 years old. Why would you expect it to be under warranty? Even if you bought the over-priced extended coverage, the parts and labor will be less than the deductible. Clocksprings with the extra circuit for the cruise control typically run around $150.00. 95 percent of that cost goes to lawyers! Takes about an hour to change it.
caradiodoc
Mar 20, 2009 at 10:12 PM
