what do you have for an engine size
Disconnect battery negative remote cable from remote ground post.
Raise vehicle.
Remove 3 bolts attaching starter to engine.
Remove battery positive feed wire from starter.
Remove starter solenoid assembly from transmission housing. Position the starter to gain access to the posi-lock wiring connector.
Position jack stand beneath engine and slightly lift to relieve pressure from left engine mount.
Remove 3 left engine mount mounting bolts from engine block.
Jack engine up slightly to give more room to maneuver starter assembly.
Slide rear of starter motor out between catalyst and engine mount.
Disconnect posi-lock starter solenoid connector.
Remove the starter from vehicle.
To install, reverse the removal procedures
Nov 18, 2009 at 10:12 AM
