1999 Plymouth Voyager Plastic fuel (gas) tanks
1999 PLYMOUTH VOYAGER
17,200 MILES • 6 CYL • 2WD • AUTOMATIC
BRV
My Plymouth GrandVoyager gas tank began to leak from the rear after running over some debris on an busy interstate highway. The insurance company and the dealer decided to replace it with a used plastic gas tank. Is it safe to use a plastic gas tank, I was told that all cars uses plastic gas tanks. Is this ture?
May 12, 2010 at 8:06 AM
BLUELIGHTNIN6
  • 16,542 POSTS
yes that is correct. the older tanks were made of steel which were very heavy, with todays fuel economy crisis the auto industry began using plastic fuel tanks which are much lighter and safer since the plastic can bend and flex instead of just crack open in an accident.
May 12, 2010 at 8:14 AM
