1999 Plymouth Voyager engine gets so hot to the top of the
CHRAAABMOM
  • 1999 PLYMOUTH VOYAGER
Air Conditioning problem
1999 Plymouth Voyager 4 cyl Front Wheel Drive
in the hot of the day my engine gets very hot and starts to bog down. Especially when I have the car in an idle. And if my ac runs it gets hot even faster and the heater bogs it down to. I dont drive a long time before this all happens it just takes as long as it takes the engine to warm up.
Tuesday, September 22nd, 2009 AT 12:58 PM
BMRFIXIT
  • 19,053 POSTS
Suspect cooling fan not coming on and need to be checked
most common is fan relay module check fuses 1st
and also should replace thermostat
do not let it over heat or an engine damage may or will occur
Thursday, September 24th, 2009 AT 6:25 AM
