the car doesn't want to start. It makes a strange noise?
1999 PLYMOUTH VOYAGER
DANAG1
  • 91 POSTS
I bought a 1999 plymouth voyager, v6, 3.3l and after i changed the battery, the car doesn't want to start. It makes a strange noise, like something is broke inside the engine or somewhere. Any idea what happened and how can be fixed? Thanks!
Oct 24, 2007 at 7:10 PM
BMRFIXIT
  • CERTIFIED EXPERT
  • 19,053 POSTS
[quote:76359c1bea="DanaG1"]I bought a 1999 plymouth voyager, v6, 3.3l and after i changed the battery, the car doesn't want to start. It makes a strane noise, like something is broke inside the engine or somewhere. Any idea what happened and how can be fixed? Thanks![/quote:76359c1bea]
you had no prblem before the new battery
did you install the battery the correct way
B+ and B-
is the battery fully charged
can you try to get jump
did you check the oil
why the battery was replaced
let us know
good luck
Oct 24, 2007 at 7:28 PM
DANAG1
  • 91 POSTS
[quote:9c3a1b3bfb="BMRFIXIT"][quote:9c3a1b3bfb="DanaG1"]I bought a 1999 plymouth voyager, v6, 3.3l and after i changed the battery, the car doesn't want to start. It makes a strane noise, like something is broke inside the engine or somewhere. Any idea what happened and how can be fixed? Thanks![/quote:9c3a1b3bfb]
B+ and B-
let us know
good luck[/quote:9c3a1b3bfb]
Well...the battery is new, just bough it from the store and yes, it is installed correctly. So..since is new and fully charged..i don't think need a jump....
Oct 24, 2007 at 7:43 PM
BMRFIXIT
  • CERTIFIED EXPERT
  • 19,053 POSTS
Some battery sits on self for a long time And many new ones I have replaced and they were defective
Oct 24, 2007 at 7:51 PM
DANAG1
  • 91 POSTS
No, the problem occur after I put the new battery. What makes me wonder is the noise that seems to came from inside the engine: it is like something is broke..
Oct 24, 2007 at 7:52 PM
DANAG1
  • 91 POSTS
The battery is manufactured this year, on july
Oct 24, 2007 at 7:54 PM
BMRFIXIT
  • CERTIFIED EXPERT
  • 19,053 POSTS
Some times if the battery don’t have enough AMPS in it The starter will make this kind of noise You can try to crank the engine by hand and listen for noises
Oct 24, 2007 at 7:57 PM
DANAG1
  • 91 POSTS
When i bought the battery, i told them for what car and what engine it have . To me look so strange how it broke like over night. Looks like is the timing belt but..not sure how broke while the car was sitting?!?
Oct 24, 2007 at 8:02 PM
BMRFIXIT
  • CERTIFIED EXPERT
  • 19,053 POSTS
3.3l its a timing chain
so the car turn over but no start and making that noise
Oct 24, 2007 at 8:03 PM
DANAG1
  • 91 POSTS
[quote:a613640535="BMRFIXIT"]3.3l its a timing chain
so the car turn over but no start and making that noise[/quote:a613640535]
exactly!
Oct 24, 2007 at 8:04 PM
BMRFIXIT
  • CERTIFIED EXPERT
  • 19,053 POSTS
do you have a lot of miles on it?
Oct 24, 2007 at 8:06 PM
DANAG1
  • 91 POSTS
How can i look or...how hard it is to look and see if the timing chain is broke? B
Oct 24, 2007 at 8:07 PM
DANAG1
  • 91 POSTS
The car have about 120,000 mi
Oct 24, 2007 at 8:08 PM
BMRFIXIT
  • CERTIFIED EXPERT
  • 19,053 POSTS
Very uncommon put possible Remove oil cap Have a helper crank the engine You watch the rocker if it move Also cycle key three times off on Read if you have codes
Oct 24, 2007 at 8:22 PM
BMRFIXIT
  • CERTIFIED EXPERT
  • 19,053 POSTS
And are you sure the noise internal. May be u take the belt off just in case it’s a pulley or alternator
Oct 24, 2007 at 8:26 PM
DANAG1
  • 91 POSTS
[quote:804e14e7bb="BMRFIXIT"]Very uncommon put possible
Remove oil cap
Read if you have codes[/quote:804e14e7bb]
If the chain is broke..it is hard to change it? And..what do you mean by cycle key three times off on? where should I see the codes?
Oct 24, 2007 at 8:27 PM
BMRFIXIT
  • CERTIFIED EXPERT
  • 19,053 POSTS
[quote:9dbbabd94b="DanaG1"][quote:9dbbabd94b="BMRFIXIT"]Very uncommon put possible
Remove oil cap
Read if you have codes[/quote:9dbbabd94b]
If the chain is broke..it is hard to change it? And..what do you mean by cycle key three times off on? where should I see the codes?[/quote:9dbbabd94b]
when you do that the check engine will binlk a
code s or on the odometer will read something like p0000 or done
its not very hard to do t chain
50/50
Oct 24, 2007 at 8:42 PM
DANAG1
  • 91 POSTS
what does 50/50 mean? any idea how to align the gears? or are there signs? and.how do i know what the codes mean?
Oct 24, 2007 at 8:47 PM
BMRFIXIT
  • CERTIFIED EXPERT
  • 19,053 POSTS
When you get ther let me know I will help 50/50 Means its not hard but not ez. You need tools and some skills
Oct 24, 2007 at 8:51 PM
BMRFIXIT
  • CERTIFIED EXPERT
  • 19,053 POSTS
its about 5 1/2 hr job
Oct 24, 2007 at 8:54 PM
DANAG1
  • 91 POSTS
well, my husband changed a timing belt at one car so, with little advice..i guess he will have some idea about it :) the problem will be i won't be home till late afternoon tomorrow to send mess on the comp. And, because here is night, i will try to do the key cycle tomorrow morning and let you know. Tks!
Oct 24, 2007 at 9:01 PM
DANAG1
  • 91 POSTS
I try to cycle the key....i saw that every time i turn it off, the light check engine lit very very little, ( lit 3 times, no blink, just lit a bit then off) also, when i try to start..this time doesn't even want to crank the engine. Try to jump it but, no work. Lights are on...also cannot see anything if open the oil cap because looks like have a metal there to cover it
Oct 25, 2007 at 6:44 AM
DANAG1
  • 91 POSTS
Hello! Well...here to give some updates: i had someone manually crank the engine and said it work. now, if i turn the ignition on, but not having the engine start, stop just before that, a noise like repeatedly knocking is heard and if try to turn the ignition like in starting the car, the car won't start. So we came up with the idea that is either a relay which is bad and stop the starter for doing its job , is the starter that is not working anymore , or both. So should i change the starter, the relay or both? What do you think or..what do you suggest!?! tks!
Oct 25, 2007 at 2:28 PM
BMRFIXIT
  • CERTIFIED EXPERT
  • 19,053 POSTS
[quote:835d1b2dad="DanaG1"]Hello! Well...here to give some updates: i had someone manually crank the engine and said it work. now, if i turn the ignition on, but not having the engine start, stop just before that, a noise like repeteadly knocking is heard and if try to turn the ignition like in starting the car, the car won't start. So we came up with the idea that is either a relay which is bad and stop the starter for doing its job , is the starter that is not working anymore , or both. So should i change the starter, the relay or both? What do you think or..what do you suggest!?![/quote:835d1b2dad]
are you sure the battery is fully charged
beside the battery u have a black box and all relays are in it
does the clicking start when you open the door
i m thinking may be an old alarm system
Oct 25, 2007 at 5:52 PM
DANAG1
  • 91 POSTS
The battery is brand new, just bought it yesterday, manufactured in july..and no, the knocking start when the ignition key is turned on, just about to start the car ( if turned to start the car, the car doesn't want to start)
Oct 25, 2007 at 6:31 PM
SERVICE WRITER
  • CERTIFIED EXPERT
  • 9,123 POSTS
Unplug the instrument cluster and It very well may start, pretty common with these clusters. They have a couple solder joints that have a problem. Battery replacement seems to create/ expose a problem. Gadzooks, stop quoting each other already
https://www.2carpros.com/forum/automotive_pictures/30961_doublevision_2.jpg
Oct 25, 2007 at 7:10 PM
DANAG1
  • 91 POSTS
What is the instrument cluster and where is located?
Oct 25, 2007 at 7:37 PM
SERVICE WRITER
  • CERTIFIED EXPERT
  • 9,123 POSTS
There you go with that quoting thing again :lol:
https://www.2carpros.com/forum/automotive_pictures/30961_skeptical1_5.jpg
IT is the gauges you look at. Speedo, fuel tank, oil light etc. You know Instrument panel. A quick test is also to bang on the dash over it and sometimes that joustles it temporarily.
Oct 25, 2007 at 7:58 PM
BMRFIXIT
  • CERTIFIED EXPERT
  • 19,053 POSTS
Ok let’s start over
You had no problem before the battery replaced
Know van don’t start and you re hearing a clicking from under the hood
You try to start the engine will not turn over
you have lights horn and radio all working
Let me know
Oct 25, 2007 at 8:16 PM
DANAG1
  • 91 POSTS
[quote:ffa1845278="BMRFIXIT"]Ok let’s start over
Let me know[/quote:ffa1845278]
Exactly. and the noise is like a knocking repeatedly and figured like starter don't want to work or some relay doesn't want to work
Oct 25, 2007 at 8:26 PM
BMRFIXIT
  • CERTIFIED EXPERT
  • 19,053 POSTS
[quote:6fef46dfdb="DanaG1"][quote:6fef46dfdb="BMRFIXIT"]Ok let’s start over
Let me know[/quote:6fef46dfdb]
Exactly. and the noise is like a knocking repeatedly and figured like starter don't want to work or some relay doesn't want to work[/quote:6fef46dfdb]
ok lets start with the noise where is it
Can u identify where the noise coming from is it
Under the hood
Driver side or pass side
With that noise is the engine trying to turn
Oct 25, 2007 at 8:35 PM
DANAG1
  • 91 POSTS
[quote:be9ad75596="BMRFIXIT"][quote:be9ad75596="DanaG1"][quote:be9ad75596="BMRFIXIT"]Ok let’s start over
Let me know[/quote:be9ad75596]
Exactly. and the noise is like a knocking repeatedly and figured like starter don't want to work or some relay doesn't want to work[/quote:be9ad75596]
Under the hood
With that noise is the engine trying to turn[/quote:be9ad75596]
yea, even with that noise, the engine try to turn...
Oct 25, 2007 at 8:46 PM
BMRFIXIT
  • CERTIFIED EXPERT
  • 19,053 POSTS
[quote:82014f6573="DanaG1"][quote:82014f6573="BMRFIXIT"][quote:82014f6573="DanaG1"][quote:82014f6573="BMRFIXIT"]Ok let’s start over
Let me know[/quote:82014f6573]
Exactly. and the noise is like a knocking repeatedly and figured like starter don't want to work or some relay doesn't want to work[/quote:82014f6573]
Under the hood
With that noise is the engine trying to turn[/quote:82014f6573]
yea, even with that noise, the engine try to turn...[/quote:82014f6573]
Please try to answer the questions
Where is the clicking
I know under the hood
Is it driver side pass side in the mid ?
Also key on you re not starting the engine you hear the noise
Is the engine trying to turn (with key on only)
Oct 25, 2007 at 8:55 PM
DANAG1
  • 91 POSTS
I don't know where under the hood, i hear it from inside, didn't have someone else trying to start and me, to be outside and look. When the key is on and about ready to start the car, i hear the noise, if i turn the key completely, the car didn't start, but still hear the noise. if i try to do that few times, at one point the engine try to start but..don't.
Oct 25, 2007 at 9:00 PM
BMRFIXIT
  • CERTIFIED EXPERT
  • 19,053 POSTS
i know u said it a new battery just for what ever try to get a jump or get the battery exchanged good luck
Oct 25, 2007 at 9:03 PM
DANAG1
  • 91 POSTS
I tried to jump it but it still wouldn't start..i will see what i will do tomorrow, thanks!
Oct 25, 2007 at 9:14 PM
SERVICE WRITER
  • CERTIFIED EXPERT
  • 9,123 POSTS
I just wanted to get in on the quote action Not tryin to step on any toes, but I ran into this once before after a battery replacement. The cluster ties into the the bcm as the diagram shows....
https://www.2carpros.com/forum/automotive_pictures/30961_01ip_1.jpg
see this post also: http://www.2carpros.com/forum/electrical-problem-vt44083.html?highlight=
Oct 26, 2007 at 6:24 AM
DANAG1
  • 91 POSTS
Found out that the noise is make when the ignition is on, by a relay which have written on it " auto shut down relay" And..how can i get too see that image? Tks!
Oct 26, 2007 at 12:18 PM
DANAG1
  • 91 POSTS
Update: The noise came from auto shutdown relay, situated between or around ac clutch relay and fuel pump relay.
Oct 26, 2007 at 12:41 PM
BMRFIXIT
  • CERTIFIED EXPERT
  • 19,053 POSTS
OK
EZ WAY swith the rElay with another SEE IF THAT HElp !!!!!!!!!!
or and you can chEck the circuit
cavity # 30 is fuSed B+
# 86 is battery +
# 85 relay control
# 87 relay out put
did u get any code s when u cycled the key
Oct 26, 2007 at 1:00 PM
DANAG1
  • 91 POSTS
[quote:cf84986580="BMRFIXIT"]OK
# 86 is battery +
# 85 relay control
# 87 relay out put
did u get any code s when u cycled the key[/quote:cf84986580]
When i cycled the key the check engine light lit so low...hardly can be seen..i don't think can count that asa a blink..
Oct 26, 2007 at 1:15 PM
