How to properly seal the side pan on the tranmission with rtv sealant
Friday, November 23rd, 2007 AT 12:28 PM
MERLIN2021
MECHANIC
Any transmission pan is better seaed with the right gasket. With the pan removed you need to remove the shap edges around the bolt holes, I do it by putting a deep socket in a vise, then using a ball peen hammer on each hole tapp gently till you flatten the scarp edge, if you don't do this, the holes cut the new gasket!
