No I don't believe it will cause your van to run bad. But im sure your like me, you want everything on your vehicle to work, whether it was "Free or not". So if you do want to fix the problem I would start with the dimmer switch (test it for continuity). If thats not the problem then I believe that your body control module may have something to do with it and that is located behind the middle pillar. It could have a connection problem with one of the wires. I had this problem with mine, one of the wires was corroded. I just pulled it out and scraped it then pushed it back in problem was solved
SPONSORED LINKS
Friday, March 28th, 2008 AT 7:46 AM
