Yesterday my van was running fine, my sister parked it for 10 mins and now it wont start, let the steering wheel unlock or shift gears. Is there a simple fix
Friday, January 8th, 2010 AT 5:34 PM
CARADIODOC
MECHANIC
"Won't start" doesn't mean much. Can I guess the ignition switch won't turn? If so, look at the direction the front tires are pointed. If turned to the side, there is likely pressure on the steering wheel lock. Just turn the steering wheel a little more in the same direction while turning the ignition switch.
Caradiodoc
Monday, January 11th, 2010 AT 4:37 AM
TIRNANOG72
MEMBER
Thank you it took 3 of us but we got it going again.
