1997 Plymouth Voyager Vehicle dies after driving 20 miles o
1997 PLYMOUTH VOYAGER
JBDNMOS
Electrical problem
1997 Plymouth Voyager 4 cyl Two Wheel Drive Automatic
1997 Plymouth Voyager, after driving the vehicle for 20 miles or so the gauges start to go crazy, the digital odometer and trip meter show various numbers the radio goes crazy, the engine spits sputters stalls and runs poorly and either dies or has to be shut off. Usually after cycling the ignition the vehicle "resets" and then starts back up, and can be drivin for another 20 miles or so and does it again sometimes the vehicle does not reset and when ignition is off a clicking noise can be heard coming from fuse block under dash, after disconnecting battery it resets and vehicle will start and drive another 20 miles or so and same all over again. Transmission was rebuilt about a month ago and this is when problem started
Jun 8, 2009 at 2:41 AM
JDL
  • 16,098 POSTS
Hello, because you mentioned the tranny, makes me wonder about the vss ? You might check for codes, see if that leads anywhere. you might also talk to the shop that did the tranny work.
Jun 8, 2009 at 2:57 AM
