My alarm went off by itself and inserting the key in the ignition and starting the engine did not stop it. The motor would not keep running and the alarm continued. The panic button on the keyless entry would not stop it either. I manually operated the key in the door locks and for some reason the alarm stopped. Don't know if there is a connection. Now the alarm is off, but when I start the vehicle all the digital transmission indicator letters on the dash board are highlighted and the van will not shift out of first gear. Can I disable the alarm system and reset the onboard computer?
Jul 26, 2008 at 7:14 AM
