1997 Plymouth Voyager POOR ENGINE PERFORMANCE IN RAIN
JMAKDISI
MEMBER
1997 PLYMOUTH VOYAGER
6 CYL
FWD
AUTOMATIC
250,000 MILES
HI, MY NAME IS JOHN AND RECENTLY MY VOYAGER HAS BEEN RUNNING POORLY IN WET WEATHER.
I BELIEVE THIS IS A DISTRIBUTORLESS IGNITION SYSTEM.I DON'T BELIEVE THE SPARK PLUGS OR WIRES HAVE BEEN CHANGED IN THE LAST 100,000 MILES. COULD THIS BE ARC JUMPING.
SPONSORED LINKS
Monday, June 8th, 2009 AT 8:33 PM
JALOPYPAPA
MEMBER
Sounds distinctly possible. Time to replace spark plugs and perhaps wires anyway. Arcing will leave a carbon trail on the plug insulator or inside the wire boot. Reinstall wire boots with a small dab of dielectric grease to prevent moisture problems in the future and make subsequent removal easier.
