1997 Plymouth Voyager need help with AC
KEYES1230
  • 1997 PLYMOUTH VOYAGER
  • 6 CYL
  • 181,000 MILES
Ok new here please help 97 plymouth voyager 181k motor gets hot but temp gage reads ok fluids ok but the ac stoped working and the ac buttons inside on dash flash for about 15 min then stop the rear air and dash air blows warm almost hot I can't hear the ac compreoss kick on when I turn the ac on? So lost:(
Wednesday, March 31st, 2010 AT 10:42 PM
CARADIODOC
  • 33,916 POSTS
The flashing leds means a problem was detected or the battery was recently disconnected or run dead. If it is a battery issue, the calibration and cooldown tests must be run although most of the functions should still work. If nothing happened to the battery, a problem with the actuators or sensors must be diagnosed and repaired, or the computer must be replaced.
Caradiodoc
Wednesday, March 31st, 2010 AT 11:29 PM
