1996 Plymouth Voyager intermediate miss
1996 PLYMOUTH VOYAGER
255,512 MILES • 6 CYL • FWD • AUTOMATIC
AUSTINANDCOMPANY
  • 5 POSTS
this started aprrox 6 months ago with a miss very seldom. however in the following months has gotten worse to the point it is no longer driveable. it started out it would not present a code, and of course it would not act up with mechanic and scanner present, lately the codes present loss of cam sensor, loss of crank sensor, loss of ground to the computer or faulty computer. and speed sensor failure, and upsteam oxygen sensor stick in middle. now i had extra parts from a parts vehicle that was wrecked and run fine. so i replaced complete disturbter including cam sensor, a complete tune-up wires plugs cap and rotor, crank sensor, grounded motor to body and grounded computer, and then replaced computer, check fuel pressure at 50 psi, replaced output speed sensor, and replaced timing belt and water pump
Apr 30, 2009 at 8:18 AM
BMRFIXIT
  • 19,053 POSTS
What do you have for codes
and after all the part replacement did you reset the PCM
let me know what you have for codes
Apr 30, 2009 at 10:50 AM
AUSTINANDCOMPANY
  • 5 POSTS
the only code i can remember is po1391 and i remember the loss of cam sensor, loss of crank sensor, loss of gound to pcm and possible faulty pcm, upstream oxygen sensor sticking in the middlle and speed sensor failure, and did not reset the pcm when i installed it used
Apr 30, 2009 at 11:22 AM
