1995 Plymouth Voyager taillite
1995 PLYMOUTH VOYAGER
JOEY956
Electrical problem
1995 Plymouth Voyager Front Wheel Drive Automatic 160.00 miles
thank you for your response!! but,how do i check for ground in taillte and fuse? in otherwords how will i know if it's good or bad ? what do i test it with? i am female and i am trying to do this myself!thank you!!
Jun 20, 2008 at 3:27 AM
JALOPYPAPA
  • 467 POSTS
You can get a 12 volt circuit tester at the auto parts store. It looks like an ice pick with a wire coming from it ending in an alligator clip.
With the lights turned on, clip the wire to the "hot" side of the circuit (the black/yellow wire terminal jdl mentioned), and touch the probe end to the black ground wire terminal and see if it lights up and/or buzzes or whatever the tester does. If not, ground instead to a clean, unpainted surface of the car's body or frame. If it works now, your ground wire is broken or loose somewhere. If neither, then your hot wire is broken, loose or shorted somewhere.
Check the fuse by opening the compartment below the dash, finding the right one from the diagram inside the cover, and pulling it out (with the power off). If it's blown, you'll see the metal inside the clear plastic is broken.
Jun 24, 2008 at 4:37 AM
