1995 Plymouth Voyager Squeeky Belt Noise
JANETM360
  • 1995 PLYMOUTH VOYAGER
Noises problem
I was told to spray WD 40 on the belt, which doesn't make sense to me. The reason it is making the noise is because of slipping. Right?
Saturday, April 11th, 2009 AT 10:09 PM
RPTASIUK
  • 7 POSTS
Firstlt, DO NOT USE belt dressing on serpentine belts. You may need a new tensioner. It is easy to replace from underneath; there is only 1 bolt holding it on. WD40 eliminates squeeling due to minor misalignment of the pulleys. The belt squeels because it rubs on the ribs of the pulley.
Sunday, September 27th, 2009 AT 6:07 PM
Related General Content
