1995 Plymouth Voyager passenger side, rear wheel leaking br
1995 PLYMOUTH VOYAGER
121,000 MILES • 6 CYL • 2WD • AUTOMATIC
FRED Z.
I bought from a neighbor who had just put in a rebuilt engineer and transmission at 117000 miles. I didn't see the brake fluid leaking until my brake warning light came on when I hit the brakes. I filled the brakes reservoir & they worked again. Now I it happened again, I swapped fuses with a known good one, no brake lights, swapped out rear bulbs, all lights work but the break lights. Any idea why it's leaking and why aren't the brake lights coming on. I'm just a novice mechanic, first time user of your service. Thanks.
Dec 2, 2009 at 7:34 AM
CARADIODOC
  • 34,381 POSTS
Two separate problems. Since you see where it's leaking brake fluid, fix that first. You'll need to bleed the line or wheel that is being serviced. If you do that with a helper pushing the brake pedal, do not push the brake pedal more than half way to the floor. Doing so will cause the seals in the master cylinder to ride in the lower half of their bores where debris and corrosion build up. That will tear the seals causing you more work and expense.
If a line is rusted through, replace the entire line from fitting to fitting if most of it is rusty. If you can find two nice clean, solid sections, you can cut the rusty part out, install fittings, make double flares, and install a small replacement section of line. Do not ever use compression fittings on steel brake line. Tie up any new steel lines to the old one with nylon tie straps or some other attaching points to prevent vibration. A vibrating steel line will become work-hardened over time and crack.
As for your brake lights, do the three center bulbs work in the liftgate? If they do, the brake light switch is working. The problem could be in the turn signal switch. If no brake lights work, try the four-way hazard flashers. If they work on the rear, that proves the bulbs, sockets, and wiring are ok. The signal lights will do the same test. If the bulbs work with the signals, suspect a defective brake light switch.
caradiodoc
Dec 12, 2009 at 3:55 AM
