1995 Plymouth Voyager engine and tranny mounts
1995 PLYMOUTH VOYAGER
CHUCKBORGES
Engine Mechanical problem
1995 Plymouth Voyager 6 cyl Front Wheel Drive Automatic
I'm haveing trouble replaceing Motor and tranny mounts for 1 I can't locate all engine mounts
Feb 2, 2010 at 3:00 AM
CH112063
  • 1,320 POSTS
With hood open. One is right in front, just look down near the center lower support, actually it bolts to the lower radiator support.
The left side(as you look) has one in front of the pulleys, and the right side has one attached to the rail and transaxle.It hangs it. Hard to get to.
Both left and right sides require removal of the plastic covers and wheels. These are all very hard to do with no hoist or air power, please be careful. If you buy the new ones you'll be able to see exactly what must come off.
Feb 4, 2010 at 1:51 PM
