1995 Plymouth Voyager
JANETM360
  • 1995 PLYMOUTH VOYAGER
Noises problem
Does Hair Spray work on noisy belts?
Saturday, April 11th, 2009 AT 10:40 PM
CARADIODOC
  • 33,975 POSTS
Try maple syrup or under-arm deodorant!
Do not put anything on serpentine belts. Dust will stick on and make the squealing worse. The proper repair is to check for proper operation of the spring-loaded tensioner pulley including tension and alignment. Often, the pivot will wear causing the pulley to be out of alignment with the other pulleys. 1/16" off-center will cause a squeal.
If the ribbed side of the belt has more than one crack per inch, it's time for a new one.
Caradiodoc
Sunday, April 12th, 2009 AT 4:13 AM
Related General Content
