1994 Plymouth Voyager Stalls When Slowing
BSBOB
My van is stalling when the RPMS drop down - when I slow down for a traffic light or slow to make a left hand turn. It doesn't do it all the time but is becoming more frequent. I have had a mechanic run a scope test on it and everything seems fine. They can't find anything wrong with it. However, it is happening so frequently that it is a real safety issue. I saw a similar problem listed and someone suggested that the temperature sensor for the computer may be malfunctioning and causing the computer to think it is too cold to run. Could this be a possibility or is there some other reason for this to be happening. Other than that it is running fine. And every time I have taken it in to a garage for diagnosis, it won't do it. Help!
Mar 16, 2006 at 11:40 AM
VANDRAGON
  • 298 POSTS
if it keeps running with your foot on the gas, it could be a weak fuel pump, clogged fuel filter or even a fuel leak. or EGR or O2 sencer gone bad.
(please excuse my grammer, it has never been one of my strong points) if the mech. used a good scanner one of these should have shown a code.
i hope this helped!
Mar 18, 2006 at 2:49 AM
Suggested Repair
Check for a weak fuel pump, clogged fuel filter, fuel leak, faulty EGR valve, or bad oxygen sensor. A good scanner should show a code if one of these is failing.
Conversation Summary
The owner of a 1994 Plymouth Voyager reports intermittent stalling when engine speed drops while slowing for lights or turns. A scope test found nothing, and the problem does not occur at the shop. The owner asked whether a faulty temperature sensor could be the cause. The expert suggested checking the fuel pump, fuel filter, possible fuel leaks, EGR, and oxygen sensor, noting that a good scanner should have set a code.
