My van shakes and shimmys
18,600 MILES • 6 CYL • FWD • AUTOMATIC
CHRISANDTOMS
Last night i was driving my van and it started shimming and shakes when i first started out but once it got up to speed it would hardly shake why would it shake and shimmy when i am going slow and not when I'm going faster?
Nov 21, 2008 at 6:26 AM
SQM
  • 6,383 POSTS
You might have a vacuum leak. Many times, a vacuum leak would be more noticeable a low engine speed but less noticeable as the vehicle drives and has higher engine speed.
It could be due to cracked hoses, it can also be due to leaking intake gasket.
Inspect for any loose or damaged hose. The intake gasket leak can be tested by spraying carb cleaner at the base of the manifold with the engine running. If there is a leak the engine will react to it and idle high. Then it will go back down.
Take a look at this guide, it covers the typical issues and how to check them:
Run through this and let me know what you find.
Nov 11, 2021 at 2:41 PM
