1992 Plymouth Voyager
RIOMASTER
  • 1992 PLYMOUTH VOYAGER
ignition switch not working unless pushed in "just so". Do I need to open steering column to replace?
Wednesday, March 24th, 2010 AT 6:35 PM
CH112063
  • 1,320 POSTS
You'll have to remove the upper and lower trim, the steering wheel can stay on with the newer models. You'll need a special torx screwdriver head, it has a small hole in it and is referred to as an inverted torx head. You'll need to go slow, and need a phillips and t-15 long torx for the trim. A small punch and hammer to remove the old key cylinder out of the old switch. It takes around an hour or so. Disconnect the battery first or you may blow a fuse.
Friday, March 26th, 2010 AT 9:32 PM
