1990 Plymouth Voyager no gage activity when ignition key tu
EPONDER
  • 1990 PLYMOUTH VOYAGER
  • 6 CYL
  • FWD
  • 183,000 MILES
Motor turns over, altanator, battery, test good. Turn on ignition switch gages don't move. No check engine or any other sign of normal gage activity. First started when driving down road and motor would cut out. Then almost as quick motor would run again. Now at point where motor tuns over but will not start and gages SHOW NO MOVEMENT LIKE NOT GETTING A SIGNAL.
Thursday, October 23rd, 2008 AT 8:59 PM
  • 109,885 POSTS
Hi:
It sounds like a ground problem. Have you checked the basics like battery terminals, battery ground at engine. If they are all good, you may want to have the BCM checked.
Let me know if you have any other questions.
Wednesday, November 5th, 2008 AT 1:36 PM
