1965 Plymouth Valiant blown fuse
1965 PLYMOUTH VALIANT
114,000 MILES • V8 • 2WD • AUTOMATIC
SAMGRAFF
my dome light and cigarette lighter are on the same fuse. when I close the door I can replace the fuse without it blowing. when I open the door or push in the lighter it blows the fuse instantly. When the door buttons spring out when the door is opened it is designed to touch ground and the light turns on. I don't understand what is happening, I've traced down the wiring and tried it by disconnecting the dome light and trying the lighter it blows the fuse. I disconnected the lighter and the dome light connected and it blows the fuse. Any help you can give will be appreciated and help me understand this dalema thanks Sam
Apr 30, 2010 at 2:12 AM
HMAC300
  • 48,601 POSTS
check your wiring behind the sdoor switches as they may be bare to far back and shorting out. same thing with the lighter although alot of times on teh lighters it was the lighter itself that was bad. Also check your undrhood light as that's the same circuit and it can be causing the problem as well.
May 19, 2010 at 7:23 AM
