1992 Plymouth Sundance Sort of a creaking noise from front
1992 PLYMOUTH SUNDANCE
87,000 MILES • 4 CYL • FWD • AUTOMATIC
SUNDANCEAMERICA
Occaisionally, when I get up to speed then let off the gas a bit, the front passenger wheel area makes a creaking noise then stops. It sounds like a rusty door creaking back-and-forth until it stops after a couple seconds. The moments that I have observed it happen, are after I have gotten up to speed and let off the gas a bit, while car is settling after I have parked, and sometimes when braking. I hope someone knows what I'm talking about, my eye twitches a bit every time it makes the noise. HAHA.
May 1, 2009 at 10:05 AM
LEGITIMATE007
  • 5,121 POSTS
sounds like you may have some safety issues, could be a couple of things, bad strut/shock. ball joints ,bushings. you must have a safety inspection done to determine exactly what it is. could possibly be a motor mount too.
May 1, 2009 at 11:01 AM
LEGITIMATE007
  • 5,121 POSTS
https://www.2carpros.com/how_to/checking_shocks_struts.htm
this will explain how to test your struts
May 1, 2009 at 11:03 AM
SUNDANCEAMERICA
WOW QUICK RESPONSE YOU GUYS ARE AWESOME! Definitely reccomending you guys to friends.
May 1, 2009 at 11:06 AM
LEGITIMATE007
  • 5,121 POSTS
thank you so much, it feels good to have our friends appreciate us
May 2, 2009 at 7:06 AM
