1994 Other Plymouth Models
1994 PLYMOUTH
113,000 MILES • 4 CYL • FWD • AUTOMATIC
DEREK9101
I,ve got a 1994 Plymouth Sundance and the heater doesn't work very well. The only time it gets warm is when you add antifreeze to the radiator. Then it gets cold again. This happens every time i add just a little antifreeze. What could be the problem?
Nov 11, 2008 at 5:29 AM
DAVE H
  • 13,383 POSTS
do you have to drain some out to add more ?? or is it disapearing ?? i think you have a circulation problem . have the vehicle pressure tested .. could be thermostat jammed or water pump not working or even a blockage somewhere in the system ?
Nov 20, 2008 at 12:13 PM
