2001 Plymouth Neon ignition
2001 PLYMOUTH NEON
105,000 MILES • 4 CYL • 2WD • AUTOMATIC
ANTHONYSTRAIT
Hello. I drove my 2001 plymouth neon today and it started fantastic never has had a problem with it starting, but i walk out side probably 4 hours after driving it to go to the store and it wont even make a noise, lights work radio works dorrs lock, so it is not the battery. But it makes 2 little click noises coming from the key hole every time you turn it. the engine does nothing. doesnt turn over absolutly nothing. can you help me? im too damn broke to take it somewhere and i would like to try to fix it myself. thanks alot!
-Anthony
Apr 1, 2009 at 2:53 PM
BLUELIGHTNIN6
  • 16,542 POSTS
Need to jumper starter terminal to ensure starter motor is working properly. If starter engages when jumpered then remove starter and have tested to ensure everything is working properly on it other than the motor. If starter is OK, suspect faulty ignition switch.
Thanks for using 2CarPros.com!
Apr 1, 2009 at 3:03 PM
