2000 Plymouth Neon disconnecting radiator fan
2000 PLYMOUTH NEON
120,000 MILES • 4 CYL • 2WD • AUTOMATIC
DKKTOBY
plug will not move red lock is down where I believe it should be.
Feb 25, 2009 at 4:24 AM
2CARPRO JACK
  • 11,533 POSTS
That lock has to slide over all of theway to unplug it.If hardly any red is visible, then it needs to go the other way.Sometimes they can be a pain, you may need to push the lock over with a small screwdriver
Feb 25, 2009 at 11:35 PM
