1996 Plymouth Neon Rear blinker won't work
123,258 MILES • 4 CYL • 2WD • AUTOMATIC
JAYRODE
I have a '96 Neon. The left rear blinker won't work but my reverse light uses the same bulb and works fine. The left front blinker blinks really fast like a bulb is blown. I replaced the rear bulb and that didn't fix it. Any ideas?
Apr 8, 2009 at 2:34 PM
BLUELIGHTNIN6
  • 16,542 POSTS
Try cleaning the contacts at the bulb housing and also ensure wiring is in good condition.
Thanks for using 2CarPros.com!
Apr 8, 2009 at 5:03 PM
CARADIODOC
  • 34,413 POSTS
So the red brake light turns white for a backup light? How did they accomplish that? Electronic flashers blink faster than normal when a bulb is burned out. Put your four-way flashers on and compare the rear lights on both sides. You'll see one is not working.
caradiodoc
Apr 17, 2009 at 6:54 PM
