1995 Plymouth Neon
AEATMON0
  • 1995 PLYMOUTH NEON
  • 4 CYL
  • FWD
  • 14,200 MILES
I have a 1995 Dodge Neon. I drove my car today with no problem, but when I went out to start it again, nothing happened. My starter was replace almost 2 years ago, but when I try to crank the car the inside lights come on, but nothing after that. It looks like a belt is missing from the side of my car sort of where the alternator belt is located. Its not the alternator belt i'm sure of that. But could this missing belt be causing the starter problem? Or or is it something else?
Tuesday, March 31st, 2009 AT 10:24 PM
EUGENE123
  • 273 POSTS
First check all fuses if they are ok go to your battery and make sure you have a good clean connection to both postive and negative terminals if yes then you ay try jumping the battery off if this also does not work then start looking at the starter relay it may be bad, if not then start looking at the starter if its not even clicking then you may have a bad ground or an open or short circuit if none of these are the problem its the starter itself
Tuesday, March 31st, 2009 AT 10:31 PM
