1999 Plymouth Breeze replaced fuel filter and car wount sta
1999 PLYMOUTH BREEZE
147,821 MILES • 4 CYL • 2WD • AUTOMATIC
ETERNALMIST
i was driving my car and right after i gave it a lil gas it made a kinda spitting noise and just shut off. i have replaced the fuel filter and checked the fuel pump but when i turn the key it just sound like its outa gas. i checked my gas pressure and im getting enough pressuse to my injectors in the front, i also check my injectors and they are getting fire im at alost for what it could be. o and for about a week before it did this i noticed a big lack of power from it
Sep 1, 2009 at 7:03 AM
All you did was replaced the fuel filter, now it won't start-check the fuel pressure again-something don't jive here. Fulel filter installed correctly?
Sep 1, 2009 at 7:12 AM
ETERNALMIST
[quote:2edba37352="rasmataz"]All you did was replaced the fuel filter, now it won't start-check the fuel pressure again-something don't jive here. Fulel filter installed correctly?[/quote:2edba37352]
yea i put the new one back in the same way the old one came out and bolted it back up with the tank strap the way it was before. i now have pressure to my injectors i didnt before i even tried spraying either in at the motor and it wouldnt crank someone told me they thought it might be the crank shaft sensor. so i am going to replace that but im not sure where on the bell housing it is well at least thats where i was told it is
Sep 2, 2009 at 4:42 AM
Both 2.0/2.4L has it on right front side of engine block-sorry no pic available.
Sep 2, 2009 at 7:14 AM
