1999 Plymouth Breeze check engine liht on
EUGENE GONCALVES
  • 1999 PLYMOUTH BREEZE
  • 4 CYL
  • FWD
  • 98,000 MILES
Code 1492 auto zone scanner said emissions problem, the auto shop said element/battery temperature sensor (circuit) another another auto shop said evap canister purge control solenoidevalve circuit. What should I do. Thank you, I hope you can help.
Monday, March 24th, 2008 AT 12:07 PM
MERLIN2021
  • 17,250 POSTS
P1492=Battery temp sensor voltage too high, the BTS ground circuit between PCM and sensor must be checked, if it's OK the PCM is no good. Chysler or a good chrysler specialty shop will be able to test it and tell you.
Monday, March 24th, 2008 AT 12:46 PM
