1998 Plymouth Breeze oil service light is on
1998 PLYMOUTH BREEZE
AWAM2026
Engine Mechanical problem
1998 Plymouth Breeze 4 cyl Front Wheel Drive Automatic 110k miles
one day the oil light came on so i went and bought some oil, but it was a different brand from what i usually use. I drove for about 5 blocks after i put in the new oil and the car started slowing down (with my foot on the pedal) it just would not accelerate, it slowed down until it came to a complete stop. i want to know what it could it be and is it something major?
Apr 20, 2010 at 4:15 PM
  • 31,937 POSTS
Hi there,
Does the engine still crank over? how low was the oil?
Mark (mhpautos)
Apr 20, 2010 at 5:16 PM
AWAM2026
well i don't know how much oil there was in it but it was still some in there and at first it started but it made a clunking sound but it would not accelerate. Then when i tried one more time it didnt really do anything but the inside functions worked just fine (meaning the lights and radio, ect.) so i really haven't done anything with it for a year or so. So now i finally can do something with the car... so i checked the oil and there was no oil in it at all but there are no oil underneath the car so i don't think there is a leak. Well i put oil in it and it turns on now but it still makes the clunking noise and it still doesn't accelerate.
Apr 21, 2010 at 5:52 AM
  • 31,937 POSTS
Hi there,
The clunk is a worry, more than likely you have damaged a bearing, i feel that you will have to check for some serious engine damage to the bearings and crankshaft.
mark (mhpautos)
Apr 21, 2010 at 10:19 AM
AWAM2026
thank you very much... but i tried it again today and it turned and the noise was very faint this time around.
Apr 21, 2010 at 12:46 PM
  • 31,937 POSTS
Hi there,
I think that if you get it hot and under load, you will get a nasty noise, if you can get it drivable it's wort a drive to see what happens.
mark (mhpautos)
Apr 21, 2010 at 2:16 PM
