1998 Plymouth Breeze Brake Problems
1998 PLYMOUTH BREEZE
BIZZOB
Brakes problem
1998 Plymouth Breeze 4 cyl Front Wheel Drive Manual
Ive replaced the master cylinder, both front calipers and pads and had the rotors turned and I still have no brakes. The pedal goes all the way to the floor like there is air in the system, but ive bled them everyway possible. Ive also bench bled the master cylinder. There is no visible leaks. What else could be the problem? My friend was telling me that there is some kind of junction box center of the vehicle that all the brake lines meet up at and it may be getting air there.
Apr 27, 2010 at 7:01 PM
  • 31,937 POSTS
Hi there,
Did you bleed the rears? try using brake hose clamps and close off all flex hoses, if the pedal is hard and high the problem is at the brakes, if still soft and low at the master cyl, try this.
mark (mhpautos)
Apr 27, 2010 at 7:27 PM
BIZZOB
yeah i bled the rears also, rr, lr, rf, lf, and gravity bled them all and ive tried every other possible bleed combinations. that is a good idea to try pinching off the flex hoses. what about that junction box, u know what part hes talking about?
Apr 27, 2010 at 7:35 PM
  • 31,937 POSTS
Hi there,
There will be a proportioning valve inn the system, but i doubt that that will be your problem.
Mark (mhpautos)
Apr 27, 2010 at 10:03 PM
TXWRIGHT
I have this same problem - what was the result?
Aug 12, 2010 at 2:19 PM
