1997 Plymouth Breeze Rough Idling
81,000 MILES • 4 CYL • FWD • AUTOMATIC
ARBR105
Car idles rough while still, seems to be better once you are moving, but when you are still, feels like you are in a massage chair.
Feb 8, 2008 at 10:42 AM
BLACKOP555
  • 10,386 POSTS
when the vehicle is the rpms staying the same or is it jummping all over the place? do you still notice the vibration at speed?
Feb 8, 2008 at 11:56 AM
CAVILIER210
My car does this too. the rpm's flutter. It's not noticable until the cars just sitting there. At speed it runs as smooth as ever.
I just got finished replacing the water pump and all the belts. along with a valve comeing out of the top of the engine (not very car literate). My car has 182000 miles on it.
i've also noticed a gas smell lately which made me think it may be the IAC motor. Could that be it?
Feb 25, 2009 at 4:47 AM
BLACKOP555
  • 10,386 POSTS
i wouldnt suspect iac module if your smelling gas. all that does it affect idle speed by changing the amount of air entering the engine.
it could be a bad iac causing that issue.
also low fuel pressure can cause that issue and cause gas smell. check the fuel pressure regulator for leaks, remove the vacuum line with engine running, if line pops off and squirts gas then it needs replacement.
I would do a commpressioint est to make sure the engine is in good shape.
Please go over this guide and report back.
Feb 25, 2009 at 10:40 AM
