1997 Plymouth Breeze No heat and coolant leak
SFS99A
  • 1997 PLYMOUTH BREEZE
  • 6 CYL
  • FWD
  • 239,000 MILES
HI folks,
I am driving a 1997 plymouth breeze. It has been slowly leaking coolant for some time. I put it in a local garage after the heater stopped working and the coolant loss increased. They replaced the thermostat and refilled the coolant, that was ten days ago. Today I topped up the coolant again after the heater stopped blowing warm air again. No change it the heater. I searched the internet for similar problems other people were having and noticed some of the answers. I just drove around the block with the heater/fan on bust, no heat. I engaged the A/C button and within 30 second warm air was coming out of the vents.
Any ideas as to what my problem may be?
Wednesday, October 21st, 2009 AT 3:11 PM
  • 109,885 POSTS
It sounds like the blend door isn't working. Have that checked. However, has the coolant leak been repaired? When it leaks, can you tell me the aprox location the leak is located under the hood?
Sunday, December 20th, 2009 AT 1:28 AM
