1994 Plymouth Acclaim Ignition
1994 PLYMOUTH ACCLAIM
11,600 MILES • 4 CYL • 2WD • AUTOMATIC
PHILLIP LITTLEFIELD
Parked car at the house & then when we got back in, the ignition switch would not even click. No response. Battery OK. Full power. Oxygen sensor replaced. Could it be the neutral safety switch or a relay?
Dec 13, 2009 at 10:05 AM
CH112063
  • 1,320 POSTS
hello, how ya making out with starting the car? all switches are safeguarded with a few different types of start realays needing a completed wire to ground through either a clutch pedal or transmission nuetral, park, switch. there are different names for different makes, yours in in front left of trans, the plug is near the l/f corner down next to the pan, with the plug removed you can simply ground a wire, drive it someplace warm, fix the problem, if grounding does nothing its best to let me know. Not good to help people start cars unsafely, but of course I'll be glad to help you get it running and back to a useful car. I worked on 100's of these. bye, let me know. been awhile
Dec 31, 2009 at 12:21 AM
