I have a annoying problem with this vehicle. When I stop the car (i.e, at a stoplight) the entire car vibrates. This vibration stops once I remove my foot from the brake pedal. If I gently touch the brake it may not happen. The vibration only occurs in forward gears not in reverse. Also, if I place the car into Neutral the vibration will go away. Could you please tell me what could be. I have already replaced the front brakes and a bad CV axle thinking that this would fix the problem and it didn't.
Nov 25, 2006 at 4:42 AM
