Sometimes when I first start out, the transmission will shift to the first gear, and then strain before shifting to the next gear; I don't continue pressing the pedal, but pull over and stop, then I press the pedal again and the transmission shifts smoothly. The transmission shifts smoothly most times. What could be causing the straining in the transmission? Thanks.
SPONSORED LINKS
Friday, May 14th, 2010 AT 7:53 PM
