hi i just saw a video on how to remove the steering box on a 2002 tahoe and i want to know if u lossen up the steering box and disconnect all the lines before u use the puller to remove the the pitman arm or can i just use the puller with out disconnecting the lines or loosen the steering box thank you
Apr 1, 2016 at 8:55 PM
